Hi i am new to adafruit and its been wonderful so far. I am testing out the sample MQTT_ethernet on arduino. Its working perfectly fine on my office internet but at home it says connection failed on the same laptop. but if i connect via a hotspot and share the internet its working. This specific isp connections are not allowing me to connect to it says connection failed.
What would be the solution to it because i want to use it at home.
Adafruit.io blocked by isp
- dastels
Re: Adafruit.io blocked by isp
It could be your WiFi router that's blocking it.
- zaffry007
already changed it. opened all the ports but only that certain ISP is having trouble connecting. Are there any other ports required ??
- dastels
Not that I am aware of. Odd. I suggest you contact them about having it whitelisted.
