1. Using Metro M4 AirLift Lite and BME280 and PCF8523
See attached Dashboard output for the code below:
while True:
t = rtc.datetime
# print(t) # uncomment for debugging
print()
print("Tom Henry's Sensor Data:")
print()
print("Today is %s: %d/%d/%d" % (days[t.tm_wday], t.tm_mon, t.tm_mday, t.tm_year))
todays_date = "%s: %d/%d/%d" % (days[t.tm_wday], t.tm_mon, t.tm_mday, t.tm_year)
print("The time is %d:%02d:%02d" % (t.tm_hour, t.tm_min, t.tm_sec))
todays_time = "%d:%02d:%02d" % (t.tm_hour, t.tm_min, t.tm_sec)
print()
print("Pressure: %.2f hPa" % sensor.pressure)
print("Pressure: %.2f psi" % psi)
# print("Pressure 2: %0.2f hpa" % bme280.pressure)
# print("Temperature 2: %0.1f C" % bme280.temperature)
print("Temperature: %.2f C" % sensor.temperature)
print("Temperature: %.2f F" % F)
print("Humidity: %.2f %% rH" % sensor.relative_humidity)
# print("Humidity 2: %.2f rH" % bme280.relative_humidity)
print("\n------------------------------------------------\n")
sleep(60)
# publish to adafruit io
io.publish("date", todays_date)
io.publish("time", todays_time)
io.publish("temperature", F)
io.publish("humidity", sensor.relative_humidity)
io.publish("pressure", psi)
2. Using Metro M4 AirLift Lite and PMSA003I
while True:
time.sleep(30)
print()
print("Concentration Units (standard)")
print("---------------------------------------")
print(
"PM 1.0: %d\tPM2.5: %d\tPM10: %d"
% (aqdata["pm10 standard"], aqdata["pm25 standard"], aqdata["pm100 standard"])
print()
PM = "%d\tPM2.5: %d\tPM10: %d" % (aqdata["pm10 standard"], aqdata["pm25 standard"], aqdata["pm100 standard"]
print("PM")
print()
print("Concentration Units (environmental)")
print(
% (aqdata["pm10 env"], aqdata["pm25 env"], aqdata["pm100 env"])
print("Particles > 0.3um / 0.1L air:", aqdata["particles 03um"])
print("Particles > 0.5um / 0.1L air:", aqdata["particles 05um"])
print("Particles > 1.0um / 0.1L air:", aqdata["particles 10um"])
print("Particles > 2.5um / 0.1L air:", aqdata["particles 25um"])
print("Particles > 5.0um / 0.1L air:", aqdata["particles 50um"])
print("Particles > 10 um / 0.1L air:", aqdata["particles 100um"])
print(“---------------------------------------")
3. Output from 2. Above
Found PM2.5 sensor, reading data...
PM 1.0: 0 PM2.5: 0 PM10: 0
Particles > 0.3um / 0.1L air: 36
Particles > 0.5um / 0.1L air: 9
Particles > 1.0um / 0.1L air: 0
Particles > 2.5um / 0.1L air: 0
Particles > 5.0um / 0.1L air: 0
Particles > 10 um / 0.1L air: 0
I will be combining 1 and 2 to send info to Adafruit IO.
I need some help on on how to publish data from the PMSA003I sensor to my dashboard.
See attached to view my current dashboard from 1 above.
I would appreciate any ideas you might have on how to send say this part of the 3 output to my dashboard:
Thank you,
Tom Henry
Adding data to my Dashboard from CircuitPython using PMSA003
- Tom_Henry
- Dashboard.png (515.01 KiB) Viewed 268 times
- brubell
- Learn User Page
Re: Adding data to my Dashboard from CircuitPython using PMS
Do you need all the readings from the PMSA003I?I need some help on on how to publish data from the PMSA003I sensor to my dashboard.
Dashboard blocks such as the line chart can display multiple feeds at once, which may be a good solution.
- Tom_Henry
Thanks for your suggestions.
I finally figured out how to separate out the different air quality particles from Adafruit PMSA003I Air Quality Breakout - STEMMA QT / Qwiic.
I am still working on my dashboard but this is how it looks today.
Tom Henry
Tom Henry
- Tom Henry Dashboard.png (473.55 KiB) Viewed 134 times
- brubell
- Learn User Page
