Is there any way to divide the sent data by 100?
I use Sigfox.and I have sent data as int16_t.
- eherrada
Re: divide the sent data by 100
I don't think so, although I may be completely wrong. If I were you I'd just divide it by 100 before you send it.
- sj_remington
Thank you for your replies.
In some platforms allow dividing/100 or do some coding on their platform to decode the data (especially if you using Lora and Sigfox).
- brubell
- Learn User Page
Yep - platforms like TheThingsNetwork allow a device to encode data prior to sending to the platform, and then the platform provides a scriptable decoder to handle decoding. Adafruit IO does not implement a decoder, the value field must be processed before it is sent to IO.weal wrote:Thank you for your replies.
