PHP Script SQL Error #1064
_phillip
Post by _phillip »
I have been trying to resolve this SQL error for longer than I care to admit. Here is the PHP script:
<?php
$temperature = $_POST['temperature'];	// nwas $_GET[]
$humidity 	 = $_POST['humidity']; 		// nwas $_GET[]
$dbname = 'pabriles_example';
$dbuser = 'pabriles_admin';
$dbpass = '.########>>>';
$dbhost = 'www.redristracards.com';
$connect = @mysqli_connect($dbhost,$dbuser,$dbpass,$dbname);
if ($connect->connect_error){
	die("Connection failed: $sql");	// my code ...
} else {
	echo "YES!!  We connnected!<br><br>";
$sql = "INSERT INTO iot_project(temperature, humidity) VALUES ('$temperature', '$humidity')";
if ($connect->query($sql) === TRUE) {
	echo "ADDED: ".$temperature.", ".$humidity;
	} else {
		echo "ERROR!!!: ".$sql."<br>".$conn->error;
$connect->close();
Serial monitor results are as follows:
And here is the SQL error message I get from the server:
I have tried using various SQL syntax checkers and each regurgitate the same exact message which is no help. I have tweaked the 'INSERT INTO ...' sql code line several ways and nothing helps. This leads me to believe that the real error has nothing to do with this line. I am going to delete the db table and re-install it and see if that helps. I have no idea what else to try.
ANY HELP will be greatly appreciated.
Thank you!
_phillip
Re: PHP Script SQL Error #1064
Post by _phillip »
I just realized that I made a mistake. The following:
was from a web page, not my serial monitor. Here is the serial monitor output:
