MQTT library disables writing to D0 and D5
this program write to the pins to check operation
Wemos D1 pin finder
Aduino pin number vs Wemos D1 mini printed number on board
0=RX
1=TX
2=D0
3=D1
4=D2
5=D5
6=D6
7=D7
8=D3
9=D4
10=D8
11=D7
#include <ESP8266WiFi.h>
Serial.begin(115200);
pinMode(D0,OUTPUT);
pinMode(D1,OUTPUT);
pinMode(D2,OUTPUT);
pinMode(D3,OUTPUT);
pinMode(D4,OUTPUT);
pinMode(D5,OUTPUT);
pinMode(D6,OUTPUT);
pinMode(D7,OUTPUT);
pinMode(D8,OUTPUT);
pinMode(RX,OUTPUT);
pinMode(TX,OUTPUT);
digitalWrite(D0,HIGH);
digitalWrite(D1,HIGH);
delay(10);
digitalWrite(D1,LOW);
digitalWrite(D2,HIGH);
delay(10);
digitalWrite(D2,LOW);
digitalWrite(D3,HIGH);
delay(10);
digitalWrite(D3,LOW);
digitalWrite(D4,HIGH);
delay(10);
digitalWrite(D4,LOW);
digitalWrite(D5,HIGH);
delay(10);
digitalWrite(D5,LOW);
digitalWrite(D6,HIGH);
delay(10);
digitalWrite(D6,LOW);
digitalWrite(D7,HIGH);
delay(10);
digitalWrite(D7,LOW);
digitalWrite(D8,HIGH);
delay(10);
digitalWrite(D8,LOW);
digitalWrite(RX,HIGH);
delay(10);
digitalWrite(RX,LOW);
digitalWrite(TX,HIGH);
delay(10);
digitalWrite(TX,LOW);
digitalWrite(D0,LOW);
delay(100);
This program shouls have operated all the pins
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#define WIFI_SSID "SSID"
#define WIFI_PASS "PASS"
#define MQTT_SERV "io.adafruit.com"
#define MQTT_PORT 1883
#define MQTT_NAME "account"
#define MQTT_PASS "Big_Number"
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, MQTT_SERV, MQTT_PORT, MQTT_NAME, MQTT_PASS);
Adafruit_MQTT_Subscribe onoff = Adafruit_MQTT_Subscribe(&mqtt, MQTT_NAME "/f/onoff");
Adafruit_MQTT_Publish LightsStatus = Adafruit_MQTT_Publish(&mqtt, MQTT_NAME "/f/LightsStatus");
void setup()
Serial.begin(9600);
pinMode(D0, OUTPUT);
pinMode(D1, OUTPUT);
pinMode(D2, OUTPUT);
pinMode(D3, OUTPUT);
pinMode(D4, OUTPUT);
pinMode(D6, OUTPUT);
pinMode(D7, OUTPUT);
pinMode(D8, OUTPUT);
pinMode(RX, OUTPUT);
pinMode(TX, OUTPUT);
digitalWrite(D0, LOW);
digitalWrite(D1, LOW);
digitalWrite(D2, LOW);
digitalWrite(D3, LOW);
digitalWrite(D4, LOW);
digitalWrite(D6, LOW);
digitalWrite(D7, LOW);
digitalWrite(D8, LOW);
digitalWrite(RX, LOW);
digitalWrite(TX, LOW);
//Connect to WiFi
Serial.print("\n\nConnecting Wifi>");
WiFi.begin(WIFI_SSID, WIFI_PASS);
digitalWrite(LED_BUILTIN, LOW);
while (WiFi.status() != WL_CONNECTED)
Serial.print(">");
delay(50);
Serial.println("OK!");
//Subscribe to the onoff topic
mqtt.subscribe(&onoff);
void loop()
//Connect/Reconnect to MQTT
MQTT_connect();
//Read from our subscription queue until we run out, or
//wait up to 5 seconds for subscription to update
Adafruit_MQTT_Subscribe * subscription;
while ((subscription = mqtt.readSubscription(5000)))
//If we're in here, a subscription updated...
if (subscription == &onoff)
//Print the new value to the serial monitor
Serial.print("onoff: ");
Serial.println((char*) onoff.lastread);
//If the new value is "ON", turn the light on.
//Otherwise, turn it off.
if (!strcmp((char*) onoff.lastread, "ON"))
//active low logic
digitalWrite(D1, HIGH);
digitalWrite(D2, HIGH);
digitalWrite(D3, HIGH);
digitalWrite(D4, HIGH);
digitalWrite(D6, HIGH);
digitalWrite(D7, HIGH);
digitalWrite(D8, HIGH);
digitalWrite(RX, HIGH);
digitalWrite(TX, HIGH);
LightsStatus.publish("ON");
else if (!strcmp((char*) onoff.lastread, "OFF"))
LightsStatus.publish("OFF");
else
LightsStatus.publish("ERROR");
else
//LightsStatus.publish("ERROR");
// if (!mqtt.ping())
// mqtt.disconnect();
void MQTT_connect()
// // Stop if already connected
if (mqtt.connected() && mqtt.ping())
return;
int8_t ret;
mqtt.disconnect();
Serial.print("Connecting to MQTT... ");
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000); // wait 5 seconds
retries--;
if (retries == 0)
ESP.reset();
Serial.println("MQTT Connected!");
MQTT
- brubell
- Learn User Page
Re: MQTT
Could you provide a link to the MQTT library you're using?
- sobellinni
Re: MQTT
now that I posted this I found it was my programming error
