Image base64 query
otills
Image base64 query
Post by otills »
I have been battling for sometime to get images displaying smoothly in an Adafruit IO Dashboard, but so far to no avail. What I can't work out is why if the image can be visible in the preview panel (Edit Layout / Edit Block / Next Step and then pasting the Base64 string in the test value), the image is not displayed when received live in the Dashboard page itself. I expect I am overlooking something obvious, but I am not sure where to look. I have tried png and jpeg, but no difference. Have also tried various resolutions - the string below is a 50 x 50 image, and while it appears as in the Block Preview window, I do not get the view updated in the Dashboard itself when I receive this, or other similar images.
This is a base64 string:
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAoHBwgHBgoICAgLCgoLDhgQDg0NDh0VFhEYIx8lJCIfIiEmKzcvJik0KSEiMEExNDk7Pj4+JS5ESUM8SDc9Pjv/2wBDAQoLCw4NDhwQEBw7KCIoOzs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozv/wAARCAAyADIDASIAAhEBAxEB/8QAFQABAQAAAAAAAAAAAAAAAAAAAAf/xAAUEAEAAAAAAAAAAAAAAAAAAAAA/8QAFAEBAAAAAAAAAAAAAAAAAAAAAP/EABQRAQAAAAAAAAAAAAAAAAAAAAD/2gAMAwEAAhEDEQA/AIyAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/2Q==
This is only a dark image, but appears in the preview window when pasted (via the steps above). This has been copied directly from data received into an Adafruit feed, yet the image is never displayed (I just see the template camera logo).
Any pointers are gratefully appreciated.
jwcooper
Re: Image base64 query
Post by jwcooper »
Thanks for this test case. I'll take a look at it, and see what's going on.
Could you also post the original image as well? Just to confirm, it's a small black square png?
otills
Post by otills »
Yes this is just a small black square. I am not in the office atm so cannot send the original image - it was made encoded following the guides online.
Have been struggling with this for quite a while..
otills
Post by otills »
Please find the image attached. Just to be clear - this is a thumbnail from a Raspberry Pi HQ camera downsampled via:
This is not pretty, but this is largely an artefact of having tried so many variations on a theme.
        print('formatting image for gsm')
        tmp = cv2.imread(path + 'img_000.jpg')
        thumb = cv2.resize(tmp, (50,50), cv2.INTER_NEAREST)
        generated_data['thumbnail'] = [thumb]
        image = Image.fromarray(generated_data['thumbnail'][0])
        stream = io.BytesIO()
        image.save(stream,format='jpeg', quality=70,optimize=True)
        stream.seek(0)
        value = base64.b64encode(stream.read())
        generated_data['image'] = str(value.decode)
Generated_data['image'] is then sent via e-mail and linked IFTTT to AdafruitIO. I had assumed this must be a formatting issue, but the image appears fine in the preview.. I have also tried changing the size and encoding between jpeg and png, but no change.
jwcooper
Post by jwcooper »
I just tested this, and the original base64 string previewed and also viewed properly within the dashboard image block.
What browser and operating system are you using?
One issue I had initially was that I copied some empty spaces prior to the base64 string. I think it would be useful if we trimmed any spaces at the beginning and end of that image data.
Here is how it looks in my dashboard:
Screenshot 2021-08-02 at 14-51-03 Adafruit IO.png (13.28 KiB) Viewed 2364 times
otills
Post by otills »
Just tried sending an image via the AdafruitIO Python API and that works fine, however when I send exactly the same data via GSM (e-mailed with an IFTTT linkage to Adafruit) the image does not get displayed (although the data appears).
I have tried a side by side comparison of these data on the Adafruit side - i.e. copying and pasting what is received using each approach and doing a 'find differences', but there are no differences. There is also no white space apparent in either.
I am running the Python/GSM code on a Raspberry Pi 4. Have tried loading the dashboard on a variety of browsers and operating systems - but am primarily using MacOS with Safari.
I have attached screenshots from the feed - i) being Python API via wired internet - preview and the data, and ii) being the equivalent for data sent via GSM and IFTTT - as you can see GSM is not treated in the same way, but I cannot see why as they appear identical.
otills
Post by otills »
Still no progress with this issue.
I can copy the received base64 image i.e 'Value' in the Feeds page, click 'Add Data' and paste it and the thumbnail appears. Yet the 'received' data is not displayed - either in the preview on the feeds page, or on the Dashboard. There are no apparent spaces, or other formatting issues being corrected via the copying and pasting.
Is this a bug, or can anyone suggest a work around? I am using the Adafruit IFTT 'Send Data to Adafruit IO' action. We are getting desperate with this now.
jwcooper
Post by jwcooper »
Can you post that new base64 string, starting with the 'i'? The one in the screenshot.
Your original string was a jpeg, this one appears to be a png.
otills
Post by otills »
Of course. Please find below. I have tried both jpeg and png and the behaviour is the same. Displays fine when manually 'added' to a feed, but not if sent to it.
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
For info, I'm using the 'Send data to Adafruit IO' IFTTT action, but have actually found the same thing happens (data received, apparently intact, but not displayed) when using MQTT (I switched to email because assumed via IFTTT in an effort to get something working.
Return to “Internet of Things: Adafruit IO and Wippersnapper”
