I am working on the IoT Air Quality Sensor with Adafruit IO project by Brent Rubell.
I am using Adafruit’s Metro M4 AirLift Lite board and have breadboarded the BME280 and PM2.5 PMS5003 sensors.
I have wired up everything and have loaded his CircuitPython Project Bundle code. I have attached the bundle code file as code.py.
I have carefully followed setting up his feeds and set up a group of feeds, see attached screenshot.
I seem to be having a problem with the feeds.
Here is the CircuitPython REPL output from Mu:
code.py output:
File "code.py", line 150, in <module>
File "/lib/adafruit_io/adafruit_io.py", line 670, in get_feed
File "/lib/adafruit_io/adafruit_io.py", line 531, in _get
File "/lib/adafruit_io/adafruit_io.py", line 500, in _handle_error
AdafruitIO_RequestError: Adafruit IO Error 401: request failed - invalid API key provided
Code done running.
Can you suggest how I might fix this?
Thanks,
Tom Henry
IoT Air Quality Sensor by Brent Rubell
- Tom_Henry
- Attachments
- Screen Shot 2021-08-01 at 3.42.28 PM.png (109.48 KiB) Viewed 158 times
- code.py
- (6.92 KiB) Downloaded 3 times
- jwcooper
Re: IoT Air Quality Sensor by Brent Rubell
Looks like it might be possible that you're missing the secrets.py file, or the AIO key is missing in that file.
Can you make sure that in addition to the code.py file in the root of the CIRCUITPY folder, you also have the secrets.py file with the following populated:
https://learn.adafruit.com/diy-air-qual ... code-usage
At the start of that page, it explains how to get that setup.
- Tom_Henry
Success!
Just replaced the Adafruit IO Key.
Thank you,
Tom Henry
PS Check out the screen shot of the dashboard.
Thank you,
Tom Henry
- Attachments
- Screen Shot Tom Henry.png (643.39 KiB) Viewed 145 times
- brubell
- Learn User Page
Looks great!
