Adafruit IO with Micropython?
- rmarlan
I would like to use Adafruit IO with Micropython not Circus Python. This is what my board requires. Is there any getting started guide or tutorial for using Micropython? Thanks!
- dastels
Re: Adafruit IO with Micropython?
Use of Adafruit IO is through either an MQTT or RESTful API, so it's language agnostic. Additionally, since CircuitPython is a fork of MicroPython it should be a fairly simple matter to get the CircuitPython AdafruitIO library running with MicroPython.
- rmarlan
@dastels
Thanks - that makes it too easy.
I didn't know if adafruit io used standard MQTT or a proprietary platform.
- brubell
- Learn User Page
rmarlan wrote:@dastels
Standard MQTT! Check out the MQTT API documentation here: https://io.adafruit.com/api/docs/mqtt.html
