I'm using the mqtt_ethernet example and I have 19 subscriptions to feeds and I notice that the bottom 5 or 6 aren't responsive to my inputs on my dashboard. I'm wondering if there is a limit to the number of feeds that I can subscribe to or if this is another issue that is frequently seen.
-Aidan
mqtt_ethernet feed subscription limit?
- aidan_the_tinkerer
Re: mqtt_ethernet feed subscription limit?
I fixed the problem... I changed #define MAXSUBSCRIPTIONS to a bigger value in mqtt.h and the problem is solved!
