ADAFRUIT HUZZAH ESP8266 Breakout GPIO0 USAGE
lunajar
Post by lunajar »
I have a question about the Adafruit HUZZAH ESP8266 Breakout. I have designed an IOT sensor and need to add an additional function through a button. I don't have the sensor with me at the moment as it is installed somewhere so I can't test this at my desk! Is it possible to use the GPIO0 button on the HUZZAH as an input button? I have written some code that will run the function after the button is held for 10 seconds. I understand that this button is used to put the board in bootloader mode. Will using the button in this way set it into bootloader mode? If so, could I set it to run the function after a double/triple press instead?
Thanks and apologies for my ignorance here!
brubell
Learn User Page
Re: ADAFRUIT HUZZAH ESP8266 GPIO0 USAGE
Post by brubell »
GPIO0 is connected to the RED LED, not the button.
If you're talking about the RST button, no, it's connected to the ESP8266 internally.
You'd need to wire up a button and resistor to one of the following GPIO pins accessible on the Feather HUZZAH: https://learn.adafruit.com/adafruit-fea ... 2824936-15
lunajar
Post by lunajar »
Hi Brubell, thanks for your reply. The device I am using is the Adafruit Huzzah ESP8266 breakout https://learn.adafruit.com/adafruit-huz ... 6-breakout. It has two buttons (1) GPIO0 and (2) RESET. I shall edit my post to be clear that I am referring to this board.
