Get function / mqtt retain flag
aidan_the_tinkerer
Post by aidan_the_tinkerer »
Does the get(); or /get function work with the Adafruit MQTT library or only with the Adafruit.IO library.
Thanks,
Aidan
aidan_the_tinkerer
Re: Get function / mqtt retain flag
Is the below an intended usage of the /get function?
Adafruit_MQTT_Subscribe stream = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME + "/feeds/stream/get");
brubell
Learn User Page
Post by brubell »
Correct, you'd want to subscribe to the following topic:
username/f/stream/get
https://io.adafruit.com/api/docs/mqtt.html#mqtt-retain
Return to “Internet of Things: Adafruit IO and Wippersnapper”
