MQTT Setup on MATRIX PORTAL
Auto101
Post by Auto101 »
Hi
I am trying to setup MQTT on matrix portal and receiving below error for ssl .
code.py output:
File "code.py", line 4, in <module>
ImportError: no module named 'ssl'
Circuit Python Ver :6.3
I have also update the the ESP firmware to NINA_W102-1.7.4 but no luck .
--Code
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import ssl
import socketpool
import wifi
import adafruit_minimqtt.adafruit_minimqtt as MQTT
# Add a secrets.py to your filesystem that has a dictionary called secrets with "ssid" and
# "password" keys with your WiFi credentials. DO NOT share that file or commit it into Git or other
# source control.
# pylint: disable=no-name-in-module,wrong-import-order
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# Set your Adafruit IO Username and Key in secrets.py
# (visit io.adafruit.com if you need to create an account,
# or if you need your Adafruit IO key.)
aio_username = secrets["aio_username"]
aio_key = secrets["aio_key"]
print("Connecting to %s" % secrets["ssid"])
wifi.radio.connect(secrets["ssid"], secrets["password"])
print("Connected to %s!" % secrets["ssid"])
### Topic Setup ###
# MQTT Topic
# Use this topic if you'd like to connect to a standard MQTT broker
mqtt_topic = "test/topic"
# Adafruit IO-style Topic
# Use this topic if you'd like to connect to io.adafruit.com
# mqtt_topic = secrets["aio_username"] + '/feeds/temperature'
### Code ###
# Define callback methods which are called when events occur
# pylint: disable=unused-argument, redefined-outer-name
def connect(mqtt_client, userdata, flags, rc):
    # This function will be called when the mqtt_client is connected
    # successfully to the broker.
    print("Connected to MQTT Broker!")
    print("Flags: {0}\n RC: {1}".format(flags, rc))
def disconnect(mqtt_client, userdata, rc):
    # This method is called when the mqtt_client disconnects
    # from the broker.
    print("Disconnected from MQTT Broker!")
def subscribe(mqtt_client, userdata, topic, granted_qos):
    # This method is called when the mqtt_client subscribes to a new feed.
    print("Subscribed to {0} with QOS level {1}".format(topic, granted_qos))
def unsubscribe(mqtt_client, userdata, topic, pid):
    # This method is called when the mqtt_client unsubscribes from a feed.
    print("Unsubscribed from {0} with PID {1}".format(topic, pid))
def publish(mqtt_client, userdata, topic, pid):
    # This method is called when the mqtt_client publishes data to a feed.
    print("Published to {0} with PID {1}".format(topic, pid))
def message(client, topic, message):
    # Method callled when a client's subscribed feed has a new value.
    print("New message on topic {0}: {1}".format(topic, message))
# Create a socket pool
pool = socketpool.SocketPool(wifi.radio)
# Set up a MiniMQTT Client
mqtt_client = MQTT.MQTT(
    broker=secrets["broker"],
    port=secrets["port"],
    username=secrets["aio_username"],
    password=secrets["aio_key"],
    socket_pool=pool,
    ssl_context=ssl.create_default_context(),
# Connect callback handlers to mqtt_client
mqtt_client.on_connect = connect
mqtt_client.on_disconnect = disconnect
mqtt_client.on_subscribe = subscribe
mqtt_client.on_unsubscribe = unsubscribe
mqtt_client.on_publish = publish
mqtt_client.on_message = message
print("Attempting to connect to %s" % mqtt_client.broker)
mqtt_client.connect()
print("Subscribing to %s" % mqtt_topic)
mqtt_client.subscribe(mqtt_topic)
print("Publishing to %s" % mqtt_topic)
mqtt_client.publish(mqtt_topic, "Hello Broker!")
print("Unsubscribing from %s" % mqtt_topic)
mqtt_client.unsubscribe(mqtt_topic)
print("Disconnecting from %s" % mqtt_client.broker)
mqtt_client.disconnect()
Last edited by adafruit_support_carter on Tue Aug 31, 2021 1:57 pm, edited 1 time in total.
Reason: added [code] tags
jerryn
Re: MQTT Setup on MATRIX PORTAL
Post by jerryn »
The code you are using is not for the matrix-portal -- it is for an esp32s2 (or something with native wifi).
The Matrrix portals is like the pyportal and uses the add-on esp32 "airlift" coprocessor
Take a look at the examples here https://learn.adafruit.com/mqtt-in-circ ... wifi-usage
for the "airlift" -- school down a ways in the page.
I hope that helps.
Note: I don't represent Adafruit. Just trying to help.
Auto101
Post by Auto101 »
I appreciate the help . The code that you mentioned is for using Adafruit I/O as MQTT broker. I run a self hosted MQTT broker and hence I am using the code that I posted .As per the guide posterd here : https://learn.adafruit.com/mqtt-in-circ ... qtt-broker , this was the code which was supposed to be used when connecting to a self hosted broker
Thanks !
jerryn
Post by jerryn »
I think you will just have to modify the part that connects to wifi to use the "airlift" modules as in the AIO example. The matrix portal with esp32 coprocessor requires a diffident configuration of the wifi as noted. The MQTT calls in the example should be OK.
Auto101
Post by Auto101 »
I have edited the code and I am able to connect to wifi but now I get a different error :
code.py output:
Connecting to WiFi...
Connected!
Attempting to connect to 192.168.XX.XXX
File "code.py", line 110, in <module>
File "adafruit_minimqtt/adafruit_minimqtt.py", line 441, in connect
File "adafruit_minimqtt/adafruit_minimqtt.py", line 243, in _get_connect_socket
AttributeError: 'NoneType' object has no attribute 'getaddrinfo'
Code done running.
Here is the code
import time
import board
import busio
from digitalio import DigitalInOut
import neopixel
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
### WiFi ###
# Get wifi details and more from a secrets.py file
try:
except ImportError:
    raise
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
# If you have an externally connected ESP32:
# esp32_cs = DigitalInOut(board.D9)
# esp32_ready = DigitalInOut(board.D10)
# esp32_reset = DigitalInOut(board.D5)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
"""Use below for Most Boards"""
status_light = neopixel.NeoPixel(
    board.NEOPIXEL, 1, brightness=0.2
)  # Uncomment for Most Boards
"""Uncomment below for ItsyBitsy M4"""
# status_light = dotstar.DotStar(board.APA102_SCK, board.APA102_MOSI, 1, brightness=0.2)
# Uncomment below for an externally defined RGB LED
# import adafruit_rgbled
# from adafruit_esp32spi import PWMOut
# RED_LED = PWMOut.PWMOut(esp, 26)
# GREEN_LED = PWMOut.PWMOut(esp, 27)
# BLUE_LED = PWMOut.PWMOut(esp, 25)
# status_light = adafruit_rgbled.RGBLED(RED_LED, BLUE_LED, GREEN_LED)
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets, status_light)
# Connect to WiFi
print("Connecting to WiFi...")
wifi.connect()
print("Connected!")
### Topic Setup ###
# MQTT Topic
mqtt_topic = "airquality/co2"
### Code ###
    # from the broker.
mqtt_client =  MQTT.MQTT(broker = secrets['broker'],
                    username = secrets['user'],
                    password = secrets['pass'],
                    port = 1883)
Last edited by adafruit_support_carter on Tue Aug 31, 2021 1:58 pm, edited 1 time in total.
Auto101
Post by Auto101 »
Can some one please help ?
Thanks !
You aren't specifying a socket pool:
https://github.com/adafruit/Adafruit_Ci ... est.py#L84
so it's None and failing when it gets here:
https://github.com/adafruit/Adafruit_Ci ... tt.py#L243
Auto101
Post by Auto101 »
Thanks for the reply . I have added the socket pool and imported it . It failed on first line with below error
code.py output:
File "code.py", line 1, in <module>
ImportError: no module named 'socketpool'
Code done running.
I have attached a screen shot showing the list of libraries that are currently on the board
Screen Shot 2021-08-31 at 1.13.53 PM.png (329.31 KiB) Viewed 158 times
For the MatrixPortal, wifi is provided by an ESP32 acting as a SPI peripheral. See the examples here:
https://github.com/adafruit/Adafruit_Ci ... s/esp32spi
for general usage.
Auto101
Post by Auto101 »
Before using the socket pool, I was able to connect to the wifi using the posted code. I 'd appreciate iff someone could provide the code for matrixportal to be ale to interact with self hosted MQTT broker . Thanks !
neradoc
Post by neradoc »
It looks like you are missing some of the init of the MQTT module ?
socket.set_interface(esp)
MQTT.set_socket(socket, esp)
minimqtt_simpletest_esp32spi.py
Auto101
Post by Auto101 »
That was it , thanks so much !
code.py output:
Connected!
