gps active anteena power connections
akmishra_99
Post by akmishra_99 »
I have GPS active anteena (GPS Antenna - External Active Antenna - 3-5V 28dB 5 Meter SMA PRODUCT ID: 960), how do I connect DC 3 to 5 V power, I need circuit schematics depicting how to connect power
mikeysklar
Re: gps active anteena power connections
Post by mikeysklar »
With these active antennas that use SMA connectors you simply connect your antenna in pin on your controller to the center pin of the SMA connector. You do not need to connect anything else. I take it you are not using our ultimate GPS module in this setup?
