Is there any way to subscribe to https://io.adafruit.com/api/v2/{usernam ... /data/last to retrieve the last known value of a feed? it's in the documentation but returns:
{"error":"not found - API documentation can be found at https://io.adafruit.com/api/docs"}.
I am attempting to read a slider value after the time it was changed. or at least compare values after an esp has been asleep. Changing the value of a slider and reading it with :
mqtt.subscribe(MQTT_USER "/feeds/slider");
if (!mqtt.connected()) {
mqtt.connect( "", MQTT_USER, MQTT_PASSWORD);
mqtt.loop();
Only returns a change if the connection is live. is there a way to tell rip van winkle what has happened ?
subscribe to past data
- TheRobertTalley
Re: subscribe to past data
so according to abachman:
mqtt.publish(MQTT_USER "/feeds/slider/get", "anything"); //to get a responce for
mqtt.subscribe(MQTT_USER "/feeds/slider"); // should be read with a proper callback.
but that doesnt work either.
this should work if the esp is waking up:Assuming I'm understanding you correctly, we have that feature for feeds already via the get() method on Feed objects in the Adafruit_IO_Arduino library. It behaves pretty much exactly like you describe. If you subscribe to an MQTT feed topic, "username/feeds/something", publishing anything to "username/feeds/something/get" will force the most recent value for the feed to be sent to just that MQTT client. If you've set up an onMessage callback, it'll trigger your code in the same way as if your feed had a new value published.
At least, that seems to be what you're describing.
We're currently figuring out how to better document the MQTT API features since we also have some more in the pipeline. For now, feature announcements come via the blog, these forums, and discord.gg/adafruit.
The feature hasn't been deployed yet for groups, but should be in the next week or two.
lastValue uses the HTTP API, which is okay if you're comfortable polling for the last value, but doesn't play nicely with active MQTT connections.
- adam b.
- adafruit forum.png (108.92 KiB) Viewed 109 times
- TheRobertTalley
pubsubclient with this rough guide seems to work:
#define sliderpub MQTT_USER "/feeds/slider"
#define sliderget MQTT_USER "/feeds/slider/get"
mqtt.subscribe(sliderpub);
mqtt.publish(sliderget, "\0");
readsub();delay(1000);readsub();
