Is an RP2040 Feather connected to an ESP32 AirLift WiFi essentially an RP2040 Nano Connect as far as WiFi is concerned?
In other words, should WiFi code on one platform run on the other with only minor changes that can be detected/adjusted by code.py?
TIA Bruce
RP2040 + ESP32 AirLift = Nano Connect??
- mikeysklar
Re: RP2040 + ESP32 AirLift = Nano Connect??
Bruce,
I think you might be able to make the AirLift function with other RP2040 variants just by making some pin changes. It is mostly an SPI connection. However, you should note that doing more advanced things like pushing updated AirLift firmware through a different controller will likely be more of a hassle than it is worth.
https://learn.adafruit.com/quickstart-r ... t-firmware
I would use at least one Feather RP2040 to test things and do firmware updates then you can experiment with other Nano RP2040's for compatibility.
- blakebr
Mike,
Thanks for your reply.
I am not looking to update the AirLift firmware. The update process looks like more work than it is worth.
My question was is a Feather with AirLift essentially a Nano Connect.
My guess is only the SPI and MOSI/MISO pin definitions would need to be accounted for.
What I don't want to do is start down the path of doing the conversion only to end up chasing my own tail.
Bruce
Bruce
- blakebr
It was so much easier than I thought it would be.
I only had to change three lines of code.
ESP_CS1, ESP_READY, and ESP_BUSY had to be defined by their GPIO pin.
- mikeysklar
Awesome. Congrats and thank you for the summary of changes.
- blakebr
The code: WiFi is defined in the variable definition area at the beginning of the code.
if (WiFi == 1): # 0=None, 1=Nano Connect, 2=AdaFruit Feather with AirLift
print("Nano RP2040 Connect in use")
# ESP32 pins aka Connect/WiFi
esp32_cs = DigitalInOut(board.CS1)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
if (WiFi == 2): # ESP32 pins aka AirLift/WiFi
print("AdaFruit RP2040 Feather in use with AirLift")
esp32_cs = DigitalInOut(board.D9)
esp32_ready = DigitalInOut(board.D10)
esp32_reset = DigitalInOut(board.D5)
# use SPI to connect to the ESP32
spi = busio.SPI(board.SCK1, board.MOSI1, board.MISO1)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
requests.set_socket(socket, esp)
- mikeysklar
Oh awesome. I didn't realize the Nano RP2040 had already made it in there.
