Node MCU Wireless Switch Delatch button
abhirupbera
Post by abhirupbera »
I have made this project with two node mcu.... https://create.arduino.cc/projecthub/sh ... -io-a9fd6b
But now the problem is after pressing pushbutton the output pin is HIGH upto when I am pressing again the pushbutton to make it LOW. My project requirement is to make the output pin HIGH as long as the input pin is HIGH. If released output will be LOW immediately.
Thanks in advance!
adafruit_support_mike
Re: Node MCU Wireless Switch Delatch button
You'll need to modify the code. As written, the code switches from one state to another. You can change it to match the current state of the tact switch.
abhirupbera
Mike, I have tried a lot. But no positive results. Please guide about the coding.
Take a look at the Digital Inputs tutorial from our Learn Arduino series:
https://learn.adafruit.com/adafruit-ard ... tal-inputs
That does what you want.
abhirupbera
Mike,
Thanks for the support. It worked like a charm but only one digital input and one output. tried to modify the code to get 3 Digital inputs & outputs, but no outcome. Please put some more light to get success.
Thanks in advance.
