AdafruitIO and ESP8266WiFiMulti?
tskunka
Post by tskunka »
OK, I am using ESP8266WiFiMulti library to have my Huzzah connect to any of a list of SSIDs that I frequent.
This works great. Now, I want to integrate AdafruitIO which I have worked with a bit in the past.
So...the Adafruit library wants the IO_USERNAME, IO_KEY, WIFI_SSID, and WIFI_PASS. It wants to manage the WiFi AND the IO.
I'm already connecting fine to WiFi..don't want to use the Adafruit WiFi so I can keep the slick multi-network thing going.
How do I use the ESP8266WiFiMulti library to manage the connection and still use AdafruitIO???
I'm at a loss...thanks for the help
jwcooper
Re: AdafruitIO and ESP8266WiFiMulti?
Post by jwcooper »
You could use the Adafruit MQTT library directly.
Example here:
https://github.com/adafruit/Adafruit_MQ ... sp8266.ino
Just swap out the ESP8266WiFi for your multi setup, and it might work OK.
