I'm doing a school project, which turns on the lights using voice command by alexa, and we used Adafruit IO for that and it worked.
But to finish the project I'm trying to make a push button connected to an ESP32 port, modify the toggle state previously activated by voice command.
How can I do this?
The code I used is on GitHub: https://github.com/DoaFx/Adafruit-LED-Code-WIFI
(I used Google translator)
Change the state of a toggle with a button ESP32
- DoaFx
- brubell
- Learn User Page
Re: Change the state of a toggle with a button ESP32
You'd want the push button to write to the same feed that the voice command writes to.But to finish the project I'm trying to make a push button connected to an ESP32 port, modify the toggle state previously activated by voice command.
We have a guide for reference on how to do this here: https://learn.adafruit.com/adafruit-io- ... ital-input
