This feed has been disabled. You can read data, but can no longer modify the feed or add new data.
What does this mean? How to fix it?
Feed has been disabled
- Franklin97355
Re: Feed has been disabled
What version of Adafruitio do you have? Adafruitio free has a 'throttle' that regulates the amount and speed you can input data.
Thank you for your reply.
I have had Adafruit IO+, and now the free version.
- jwcooper
When you downgrade from IO+, the feed limit is set to 10 feeds. Any feeds over that limit are disabled and unable to be used. You can delete those feeds if you'd like. I believe we keep the 10 most recently used feeds, and disable the rest.
When downgrading, there should be a pretty clear description of how it all works.
