Feed has been disabled
weal
Post by weal »
This feed has been disabled. You can read data, but can no longer modify the feed or add new data.
What does this mean? How to fix it?
Franklin97355
Re: Feed has been disabled
Post by Franklin97355 »
What version of Adafruitio do you have? Adafruitio free has a 'throttle' that regulates the amount and speed you can input data.
weal
Post by weal »
Thank you for your reply.
I have had Adafruit IO+, and now the free version.
jwcooper
Post by jwcooper »
When you downgrade from IO+, the feed limit is set to 10 feeds. Any feeds over that limit are disabled and unable to be used. You can delete those feeds if you'd like. I believe we keep the 10 most recently used feeds, and disable the rest.
When downgrading, there should be a pretty clear description of how it all works.
