DNS Failed for io.adafruit.com
vini10vini10
Post by vini10vini10 »
When i was trying out the second exemple sketch (from the adafruit io arduino libary) on my esp32 it didn't work . When i looked in the serial monitor i got this message:
Connecting to Adafruit IO[E][WiFiGeneric.cpp:739] hostByName(): DNS Failed for io.adafruit.com
[E][WiFiClientSecure.cpp:133] connect(): start_ssl_client: -1
Network disconnected.
When I tried the first exemple sketch it did work.
Can anyone help me out?
Vincent
mikeysklar
Re: DNS Failed for io.adafruit.com
Post by mikeysklar »
Is the error still occuring or was it transient?
My guess is that it is one of two things if it continues:
1) An incorrect DNS server is being set by your DHCP server or within the example code.
2) An incorrect gateway is being used so your queries are not reaching the DHCP server.
If you want to paste your example code that is running minus username and API key that might show something. Even better to see what the DHCP is providing for gateway and DNS sever to confirm those are good.
vini10vini10
The error is still occuring. This is the code like you asked.
tia
// Adafruit IO Subscription Example
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// set up the 'counter' feed
AdafruitIO_Feed *counter = io.feed("counter");
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while(! Serial);
  Serial.print("Connecting to Adafruit IO");
  // start MQTT connection to io.adafruit.com
  io.connect();
  // set up a message handler for the count feed.
  // the handleMessage function (defined below)
  // will be called whenever a message is
  // received from adafruit io.
  counter->onMessage(handleMessage);
  // wait for an MQTT connection
  // NOTE: when blending the HTTP and MQTT API, always use the mqttStatus
  // method to check on MQTT connection status specifically
  while(io.mqttStatus() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // Because Adafruit IO doesn't support the MQTT retain flag, we can use the
  // get() function to ask IO to resend the last value for this feed to just
  // this MQTT client after the io client is connected.
  counter->get();
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  // Because this sketch isn't publishing, we don't need
  // a delay() in the main program loop.
// this function is called whenever a 'counter' message
// is received from Adafruit IO. it was attached to
// the counter feed in the setup() function above.
void handleMessage(AdafruitIO_Data *data) {
  Serial.print("received <- ");
  Serial.println(data->value());
config file:
/************************ Adafruit IO Config *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define IO_USERNAME  "x"
#define IO_KEY       "x"
/******************************* WIFI **************************************/
// the AdafruitIO_WiFi client will work with the following boards:
//   - HUZZAH ESP8266 Breakout -> https://www.adafruit.com/products/2471
//   - Feather HUZZAH ESP8266 -> https://www.adafruit.com/products/2821
//   - Feather HUZZAH ESP32 -> https://www.adafruit.com/product/3405
//   - Feather M0 WiFi -> https://www.adafruit.com/products/3010
//   - Feather WICED -> https://www.adafruit.com/products/3056
//   - Adafruit PyPortal -> https://www.adafruit.com/product/4116
//   - Adafruit Metro M4 Express AirLift Lite ->
//   https://www.adafruit.com/product/4000
//   - Adafruit AirLift Breakout -> https://www.adafruit.com/product/4201
//   - Adafruit AirLift Shield -> https://www.adafruit.com/product/4285
//   - Adafruit AirLift FeatherWing -> https://www.adafruit.com/product/4264
#define WIFI_SSID "x"
#define WIFI_PASS "x"
// uncomment the following line if you are using airlift
// #define USE_AIRLIFT
// uncomment the following line if you are using winc1500
// #define USE_WINC1500
// comment out the following lines if you are using fona or ethernet
#include "AdafruitIO_WiFi.h"
#if defined(USE_AIRLIFT) || defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE) ||         \
    defined(ADAFRUIT_PYPORTAL)
// Configure the pins used for the ESP32 connection
#if !defined(SPIWIFI_SS) // if the wifi definition isnt in the board variant
// Don't change the names of these #define's! they match the variant ones
#define SPIWIFI SPI
#define SPIWIFI_SS 10 // Chip select pin
#define NINA_ACK 9    // a.k.a BUSY or READY pin
#define NINA_RESETN 6 // Reset pin
#define NINA_GPIO0 -1 // Not connected
#endif
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS,
                   NINA_ACK, NINA_RESETN, NINA_GPIO0, &SPIWIFI);
#else
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
#endif
/******************************* FONA **************************************/
// the AdafruitIO_FONA client will work with the following boards:
//   - Feather 32u4 FONA -> https://www.adafruit.com/product/3027
// uncomment the following two lines for 32u4 FONA,
// and comment out the AdafruitIO_WiFi client in the WIFI section
// #include "AdafruitIO_FONA.h"
// AdafruitIO_FONA io(IO_USERNAME, IO_KEY);
/**************************** ETHERNET ************************************/
// the AdafruitIO_Ethernet client will work with the following boards:
//   - Ethernet FeatherWing -> https://www.adafruit.com/products/3201
// uncomment the following two lines for ethernet,
// #include "AdafruitIO_Ethernet.h"
// AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);
mikeysklar
Alright, let's figure out what is on the console and follow the FAQ for troubleshooting.
Please post your console output in CODE tags after setting this up.
My Serial Monitor prints "..." endlessly after the "Connecting to Adafruit IO" message
Your board is not connecting to Adafruit IO, but why? Let's find out:
First, check in config.h that you have the correct IO_USERNAME, IO_KEY, WIFI_SSID, and WIFI_PASS are set correctly.
Next, we're going to modify the while loop which waits for an IO connection in your sketch. Change the line in the status check loop from Serial.println(.);to Serial.println(io.statusText());
// wait for a connection
while(io.status() < AIO_CONNECTED) {
delay(500);
Verify and re-upload the sketch. If you're receiving a Network disconnected error message, the board is not able to talk to the internet. Re-check your hardware, connections, and router settings.
If it's still not showing Adafruit IO connected, check the IO status on the Adafruit Status page to make sure the service is online.
https://learn.adafruit.com/adafruit-io- ... uit-io-faq
Return to “Internet of Things: Adafruit IO and Wippersnapper”
