struct_time(tm_year=2000, tm_mon=1, tm_mday=1, tm_hour=8, tm_min=19, tm_sec=3, tm_wday=5, tm_yday=1, tm_isdst=-1)
Everything I read says this should give me the current time but this time is obviously incorrect. I know my connection to Adafruit IO is good because I am able to send and receive temperature test data. Please help, thanks!
# adafruit_circuitpython_adafruitio usage with an esp32spi_socket
from random import randint
import board
import time
import busio
from digitalio import DigitalInOut
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi
import adafruit_requests as requests
from adafruit_io.adafruit_io import IO_HTTP, AdafruitIO_RequestError
# Add a secrets.py to your filesystem that has a dictionary called secrets with "ssid" and
# "password" keys with your WiFi credentials. DO NOT share that file or commit it into Git or other
# source control.
# pylint: disable=no-name-in-module,wrong-import-order
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.A5)
esp32_ready = DigitalInOut(board.A4)
esp32_reset = DigitalInOut(board.A3)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
print("Connecting to AP...")
while not esp.is_connected:
try:
esp.connect_AP(secrets["ssid"], secrets["password"])
except RuntimeError as e:
print("could not connect to AP, retrying: ", e)
continue
print("Connected to", str(esp.ssid, "utf-8"), "\tRSSI:", esp.rssi)
socket.set_interface(esp)
requests.set_socket(socket, esp)
# Set your Adafruit IO Username and Key in secrets.py
# (visit io.adafruit.com if you need to create an account,
# or if you need your Adafruit IO key.)
aio_username = secrets["aio_username"]
aio_key = secrets["aio_key"]
# Initialize an Adafruit IO HTTP API object
io = IO_HTTP(aio_username, aio_key, requests)
timenow = time.localtime()
print(timenow)
try:
# Get the 'temperature' feed from Adafruit IO
temperature_feed = io.get_feed("temperature")
except AdafruitIO_RequestError:
# If no 'temperature' feed exists, create one
temperature_feed = io.create_new_feed("temperature")
# Send random integer values to the feed
random_value = randint(0, 50)
print("Sending {0} to temperature feed...".format(random_value))
io.send_data(temperature_feed["key"], random_value)
print("Data sent!")
# Retrieve data value from the feed
print("Retrieving data from temperature feed...")
received_data = io.receive_data(temperature_feed["key"])
print("Data from temperature feed: ", received_data["value"])
print(timenow)
