Hi. I am working on a CheerLights feed that is native to Adafruit IO. I am having trouble with one of the API endpoints from the documentation "data/last"
Here's my public feed: https://io.adafruit.com/api/v2/cheerlig ... /data/last
Without the last endpoint, the feed returns. Does anyone know what might be wrong? Only supports numerical last?
Thanks for the help.
Getting the last data feed
- jwcooper
Re: Getting the last data feed
The 'last' call is a write mode method that will read the last read value of the feed (it works in conjunction with 'first', 'next', 'previous'). That's the reason it won't work on a public feed. Only read-only methods work on public feeds.
I'd like to change that to work with public feeds (particularly 'last'), but in the meantime, you could use the 'retain', if csv is ok:
https://io.adafruit.com/api/v2/cheerlig ... ata/retain
- cheerlights
Thanks. That is suitable for now. I +1 the idea to have those data endpoints map to public feeds.
