I was doing just fine compiling adafruit io sketches for teensy 4.1 using airlift, now I am getting errors, most of them variable scope errors in Please fix!!!
Build log attached as file:
Teensy 4.1 compile gives errors
- zzcrow
- build_log.txt
- (1.11 KiB) Downloaded 6 times
- zzcrow
Re: Teensy 4.1 compile gives errors
Seems like Arduinohttp client is the problem, it is still in beta, I think it has been added recently, I did not start having any problems until I updated Adafruit IO. It used to compile for the teensy 4.1 OK. My updated library does work with grand central though. Fix!!! I bought 3 teensy 4.1 boards ($36 each!!!) to use with this...(Once I got the first one to work)
- brubell
- Learn User Page
Please file an issue on the Adafruit IO Arduino repository: https://github.com/adafruit/Adafruit_IO_Arduino/issues. On the issue, include as much detail as possible including the full compilation error log.
ArduinoHTTPClient hasn't been updated in a while, https://github.com/arduino-libraries/ArduinoHttpClient
