MQTT Topic Path Depth
sdyoung
Post by sdyoung »
I'm using a software package that has an API that more or less doubles as the MQTT topic path. So in a browser to get a value the URL would be <server>/state/circuit/get/6 and to set it <server>/state/circuit/set/6/true. The MQTT it generates wants to write to that same path structure. I can't see how to build feeds in AIO with that path depth. I can see AIO transforming the slash delimiters into hyphens. Do I need to somehow accommodate that transformation or is there a way in AIO to build deeper paths? I thought about trying to somehow shorten the path in AIO to <username>/feed/6 but on the source side, there is a /6 in /circuits, /pumps, /lights and so on.
Of course maybe I'm just missing something obvious.
jwcooper
Re: MQTT Topic Path Depth
Post by jwcooper »
Here is our detailed documentation on our MQTT broker:
https://io.adafruit.com/api/docs/mqtt.h ... o-mqtt-api
And specifically, here is how we expect mqtt topics to be formatted:
https://io.adafruit.com/api/docs/mqtt.html#mqtt-topics
sdyoung
Post by sdyoung »
Thanks for posting that, and yes, I've read that info. It seems somebody else had this same question in 2017 viewtopic.php?t=118664
Can you confirm the only way to have two similar path elements with different upstream elements to separate with hyphens?
Like this:
<username>/feeds/state/circuit/6 and <username>/feeds/states/pump/6
would have to be represented as
<username>/feeds/state-circuit-6 and <username>/feeds/states-pump-6
That's all we can do on AIO?
jwcooper
Post by jwcooper »
That's correct. We have to map the topic to your username and the feed that you would like to save the data.
We also support groups, which adds one more level, but the topic changes only slightly:
https://io.adafruit.com/api/docs/mqtt.html#group-topics
Groups allow you to publish multiple feeds in a single publish, but you'd still need to modify your topic paths.
