Wifi Access Points
- atilliator
Wifi Access Points
I am looking for an IOT platform that allows for devices to connect to WiFi without SSID & PASS being included in the sketch. I am currently using tzapu WifiManger Access Point on Huzzah feather. Is there any documentation on how to do this with Adafruit IO?
- rpiloverbd
Re: Wifi Access Points
You could create your own WiFi Router, you need to use any IoT module in Access Point Mode and need to create a WebServer, its quite simple, you can check one tutorial here: https://www.theengineeringprojects.com/ ... -mode.html
They have used ESP32 module but you will get the main idea of Access Point Mode.
Create a Web Server in Access Point Mode and then connect your devices with that network, simple and doable solution.
- santawang
I did everything, thanks for help.rp wrote:You could create your own WiFi Router, you need to use any IoT module in Access Point Mode and need to create a WebServer, its quite simple, you can check one tutorial here: https://www.theengineeringprojects.com/ ... -mode.html
They have used ESP32 module but you will get the main idea of Access Point Mode. io games
