Hi looking for connect to IO with my Arduino WiFi MKR 1010. Is there a version of the library that supports that (or a tweak I can make to make the current library work for it ? )
Is there a arduino library for IO that works with the MKR 10
- darumsdad
- brubell
- Learn User Page
Re: Is there a arduino library for IO that works with the MK
We did have a pull request for this, which was closed due to inactivity (not due to content) if you're interested in trying this and re-opening a new PR: https://github.com/adafruit/Adafruit_IO ... o/pull/136
Otherwise, I'd suggest using the Adafruit MQTT library instead.
- darumsdad
Sure. I’ll give it a shot.
- darumsdad
Hi - PR posted .. thanks
David
David
- brubell
- Learn User Page
Thanks David, added to lastest release https://github.com/adafruit/Adafruit_IO ... /tag/4.2.0
