Why did my IO Key Change?
mmicatka
Post by mmicatka »
I was working on a project using the ESP8266 board integrating with a MQTT feed through Adafruit IO.
Everything was working fine, I left my project running for a few hours to make sure things were gravy.
After ~6 hours, my devices stopped working and, upon further investigation, I realized it was because my API key had changed. I definitely didn't do this (I didn't do ANYTHING, just left it running). And I'm confident the key changed (as opposed to a typo) because that same API key was hardcoded into a bunch of projects that all were working and stopped at the same time.
What happened? Why would this happen? Was there some auto-regen to do with requests? I was only making MQTT pings every few hours at most.
I'm making this wifi device as a holiday gift for someone, so I'd like to resolve this before I hand it over! Any help is appreciated.
EDIT:
I got a *belated email from Adafruit explaining things! I pushed my code to my github and the config file included my IO key - I had accidentally set the repo visibility to public. As a result, Adafruit automatically reset my key.
As an aside, I'm confused why this:
Serial.print(mqtt.connectErrorString(ret));
Returns this:
Connection Failed
I finally debugged my issue by looking at a sample python script that returned this error message:
Adafruit IO request failed: 401 Unauthorized - request failed - invalid API key provided
Which is far more helpful. What's the corresponding function to get this info on the arduino side?
brubell
Learn User Page
Re: Why did my IO Key Change?
Post by brubell »
For security purposes, we have an automation set up to revoke and reassign keys that were posted publicly on GitHub.
If you're using the Adafruit MQTT Arduino library - that's a library designed to work with any MQTT broker and the expected return response.
The Adafruit IO Arduino (https://github.com/adafruit/Adafruit_IO_Arduino) and Adafruit IO Python libraries sit on top of the Adafruit MQTT library and offer status states specific to Adafruit IO - https://github.com/adafruit/Adafruit_IO ... ons.h#L138
