Command: upip.install('adafruit-io')
Result: ... "Error installing 'requests': , packages may be partially installed.
I get the feeling I might be running out of memory, but this is after a fresh flash. Any ideas what's going on?
MicroPython on ESP32 - can't install adafruit-io library
- karltbraun
- brubell
- Learn User Page
Re: MicroPython on ESP32 - can't install adafruit-io library
Not entirely sure as the Adafruit IO Python + CircuitPython library is unsupported for MicroPython. We have official CPython and a CircuitPython library support for Adafruit.io, not micropython. You may have better luck running the Micropython uMQTT client along with the MQTT API for IO if there is no official library https://io.adafruit.com/api/docs/mqtt.h ... o-mqtt-api
- karltbraun
Thanks for the reply. If I'm understanding you, I can take the MQTT setup I had working with my own on-prem broker (umqttsimple library) and configure it to talk to the Adafruit IO broker?
- karltbraun
I've since come discover that you can use the umqtt.simple library to connect to the Adafruit IO setup. You will of course need to connect with a username and password (which will be the account key), and your topic needs to be in a format which maps to the MQTT key for your feed.
- brubell
- Learn User Page
Correct - the "Adafruit IO" client libraries provide the correct topic/feed mapping along with other helper functions.karltbraun wrote:I've since come discover that you can use the umqtt.simple library to connect to the Adafruit IO setup. You will of course need to connect with a username and password (which will be the account key), and your topic needs to be in a format which maps to the MQTT key for your feed.
Topic formatting is discussed in the Adafruit IO MQTT API documentation: https://io.adafruit.com/api/docs/mqtt.html#mqtt-topics
