Hey folks! I am SUPER DUPER new to circuit python, but have managed to cobble together an environmental sensor package that I intend to put on my boat in the spring. It's an ESP32-S2 feather with a 1306 OLED panel and a BMP280, among other things. It connects to Adafruit IO, and pushes my data, and runs and runs, and everything is fine. However, every 12-36 hours, it will drop offline. The last message I see on the OLED is a complaint about a handshake, and when I hit the reset button, everything reconnects and is fine for another 12-36 hours.
My question is this: what is the proper way to handle this error? Is it possible to have the device automatically reset when it has a network error? I couldn't find any good docs about error handling, when I search for it, I just get the generic troubleshooting guide, and that doesn't help me here.
Disconnects and error handling
- brubell
- Learn User Page
Re: Disconnects and error handling
Are you able to obtain the error from the REPL? Can you copy and paste it here?. However, every 12-36 hours, it will drop offline. The last message I see on the OLED is a complaint about a handshake, and when I hit the reset button, everything reconnects and is fine for another 12-36 hours.
- T_Mo
I'm interested in this topic also, I can post an applicable exception error if needed.
- Rcayot
I am also interested. Occasionally my internet (satellite based) goes offline due to weather etc. When this happens the error crashes the program running the code to post data on AIO. I would like to know how to trap that error and reconnect automatically say every hour or so,
Roger Ayotte
Roger Ayotte
- jwcooper
Here is a fairly comprehensive demo of how you can make it a bit more resilient:
https://gist.github.com/tylerdcooper/91 ... d8eb1a5fce
Notice most networking calls are wrapped in try/except blocks, each block handling things in different ways. Reading from i2c devices is also wrapped in try/except and handled to prevent crashes.
This particular sketch goes into a deep sleep and there is no loop, as it's way easier than trying to maintain connection state. Once the device wakes up (every 180 seconds), it just starts all over again from the top, any critical errors, and it goes back to sleep to try again.
If you wanted to do this in a loop and not sleep, you'd need to check if wifi is still connected, etc (if not re-run the connect function, etc).
- IamNabil
I am able to see most of it on the OLED screen. It's an SSL handshake error. I bought an adalogger, so I'll try to have the logs export. Lately, it's been every couple of days, so it may be a bit before I am able to get it to crash again.brubell wrote:Are you able to obtain the error from the REPL? Can you copy and paste it here?. However, every 12-36 hours, it will drop offline. The last message I see on the OLED is a complaint about a handshake, and when I hit the reset button, everything reconnects and is fine for another 12-36 hours.
I apologize for not replying earlier, I had notifications turned off, and didn't know anyone had responded.
