Huzzah ESP8266 breakout not connecting to Adafruit IO
bujones
Post by bujones »
I am trying to get connected to Adafruit IO using a Huzzah ESP8266 breakout and it never connects. I have followed the setup for the breakout board and can connect to my WiFi. When I try and connect using the Example Adafruit IO Arduino publish sketch and the Temp & Humidity sketch I get the message disconnected from Adafruit IO.
I am using the following versions of these libraries:
Adafruit IO Arduino 4.2.0
Adafruit ESP8266 1.1.0
Adafruit MQTT 2.4.2
When I look at the monitor page for Adafruit IO I do not see any errors or any connections. I have verified that my ID and Key are correct using a Python script to connect. I'm not sure where to go from here.
bujones
Re: Huzzah ESP8266 breakout not connecting to Adafruit IO
Post by bujones »
This morning I tried to connect using the MQTT client with Python on my Mac and am still unable to connect using the examples from https://github.com/adafruit/Adafruit_IO_Python. Right now I'm not sure what to do next. Any assistance would be appreciated.
jwcooper
Post by jwcooper »
Did you get any errors locally while trying to connect on the mac? That's a good approach to help debug this issue, I think.
bujones
Post by bujones »
Here is the stack trace when I try and connect using Python on my Mac.
File "adiomq.py", line 49, in <module>
client.connect()
File "/Library/Python/3.8/site-packages/Adafruit_IO/mqtt_client.py", line 150, in connect
self._client.connect(self._service_host, port=self._service_port,
File "/Library/Python/3.8/site-packages/paho/mqtt/client.py", line 914, in connect
return self.reconnect()
File "/Library/Python/3.8/site-packages/paho/mqtt/client.py", line 1044, in reconnect
sock = self._create_socket_connection()
File "/Library/Python/3.8/site-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/socket.py", line 808, in create_connection
raise err
File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/socket.py", line 796, in create_connection
sock.connect(sa)
socket.timeout: timed out
It just times out when it tries to connect.
bujones
Post by bujones »
This morning I was reading an older post and found this one:
viewtopic.php?f=56&t=167371&hilit=esp82 ... te#p819909
I saw that using WiFi from a thethered phone they were able to connect, so I gave it a try and what do you know it worked. This tells me that xFinity appears to be blocking the connection. I will need to investigate this and figure out what is happening.
jwcooper
Post by jwcooper »
Thank you for following up with the solution or root cause. Will be interesting to see what you find out about how/why xfinity is blocking the connection.
