When I try to create an IO action, I get:
"Error: request failed - authentication failed, missing token requested"
See this video for what happens:
http://somup.com/c3e3hgTKyY
Thanks for your help.
-- Al
- science_al
- mikeysklar
Re: Error: request failed - authentication failed, missing t
Al,
Have you been able to setup your AIO keys for authentication?
https://io.adafruit.com/api/docs/#authentication
- science_al
Yes, I've set up an AIO key and am using it successfully with a different device.
- jwcooper
Are you able to do anything else in IO? Create a feed, or add data to a feed (via the web from the feed page)?
One quick suggestion is try signing out of IO and signing back in. Based on the error message, it looks like the authentication is failing (which isn't related to the AIO Key, in this case).
Did this just start happening as well? Does IO work in a different browser?
