I have esp32-s2 -Adafruit IO
re set ssid & pswd for wifi and Network for the UF2 file, saved and up loaded.
Tried to see all type in as correct after uploading to board file on my "E directory"...seems to be correct
Set up Whipper snapper, cannot add component (aht20) Temp sensor, does not show up?
says off line???
Is it time to Deleat all and start over
Bill M
ESP32 & Whippersnapper says offline
- mikeysklar
Re: ESP32 & Whippersnapper says offline
Have you been running beta29?
https://github.com/adafruit/Adafruit_Wi ... o/releases
Is there anything in the log file on the ESP32-S2 boot device?
What color patterns do you see on the LED?
- Fibbermcg
Yes to beta 29,
Cyan, then blue, then turns off an then blue flash x4 times, turns solid red, then repeats.
Thanks for the reply. I am new and a lot of lingo is throw out to follow.
- brubell
- Learn User Page
Which board, exactly, do you have? Could you provide a product link so we can better assist you?I have esp32-s2
- Fibbermcg
Adafruit #5000
Trying to utilize the No code temp & humidity as shown in that description...https://www.adafruit.com/product/5000.. ... mp-tracker
Using both components.
Bill
Bill
- Fibbermcg
- Fibbermcg
This was the only code I changed. file name (secrets.json)
"io_username": "xxxxx",
"io_key": "xxxxx",
"network_type_wifi_native":{
"network_ssid": "xxxxx",
"network_password": "xxxxx"
Each of the 5 xxxxx were revised to my router ssid/pswd and Adafruit IO name and key. So simple I thought and I do not see what I missed.
bill
"io_key": "xxxxx",
bill
- freddyboomboom
If you have a Rev B or Rev C board, there is a fix coming in Wippersnapper Beta 30 for this: https://github.com/adafruit/Adafruit_Wi ... issues/239
See also this thread: viewtopic.php?f=56&t=189907
- brubell
- Learn User Page
Could you try installing the latest version of Adafruit IO WipperSnapper (https://github.com/adafruit/Adafruit_Wi ... .0-beta.30) and trying again?
- Fibbermcg
Will try v30. Could not find the board version though. Family vacation, will delv into again Friday 15th.
Thanks, Bill
Thanks, Bill
- freddyboomboom
I am not the Original Poster, however I have tested beta.30 for the Feather ESP32-S2 with TFT, without TFT but with BME280, and without TFT and without BME280 and it worked on all three.
Just an FYI for the OP and Adafruit support.
