Hello All,
I am trying to run the simple publish example for AdafruitIO with my Huzzah32. I am in an educational network, so my only wifi options are either with username + password, or the open network (no password). I guess that the first option is ruled out. I successfully connected with the wifi connect example to the open network (I just didn't include the password parameter), however in the publish example for AdafruitIO, when I do not feed it a password it gives me an error. Is there any possibility to connect with no password and use the publish example?
Thanks for your time.
HUZZAH32 – ESP32 AdafruitIO Connection Issue
- brubell
- Learn User Page
Re: HUZZAH32 – ESP32 AdafruitIO Connection Issue
Not presently, it'd need to be added to the library. You may want to file an issue here, keeping in mind that there's no ETA for issues being resolved: https://github.com/adafruit/Adafruit_IO ... issues/newIs there any possibility to connect with no password and use the publish example?
Why are you unable to connect using the WiFi's username/password?
- dchatzin
The problem is that for the secured network, I need to login with my school credentials (username and PW). In that case there are 3 parameters, the network's ssid, and my username and password.Why are you unable to connect using the WiFi's username/password?
Thank you for the quick response. I will open an issue as you suggested.
