I have an esp8266 with Arduino Uno I am using to post data to a feed on Adafruit IO and it works great. The Adadfruit part is running entirely on the esp8266. I am using feed->save(data) (feed is an AdafruitIO_Feed object) and the data uploads fine. But I can't read from any feeds. If I use feed->last value() Null is returned, and if I try and use
feed->onMessage(handleMessage);
feed->get();
It is never triggered when the feed changes value.
Is there something I need to do on the site to allow it to read? I am copying from the examples on git hub almost exactly so I don't understand why it won't work.
I been stuck on it for hours so any help is appreciated.
Thanks for your help in advanced.
Feed read
- dastels
Re: Feed read
Are you calling io.run(); in your loop?
DaveNext, we have the main loop() function. The first line of the loop function calls io.run(); this line will need to be present at the top of your loop in every sketch. It helps keep your device connected to Adafruit IO, and processes any incoming data.
- marafino
Re: Feed read
Yes I am.dastels wrote:Are you calling io.run(); in your loop?
Appreciate your response
- jwcooper
Re: Feed read
It might be useful to take a look at this example:
https://github.com/adafruit/Adafruit_IO ... _02_pubsub
Make sure that's working for you, and then compare where things can get updated in your code. It's a good example of writing to a feed, and then reading that value.
There are a lot of examples in the parent folder that may help too.
