Hi Everyone,
I'm trying to get a simple project up and running with a SIM7600 connected to an Arduino, checking the temperature and humidity once every 10 minutes, and uploading the results to Adafruit.io.
I decided the easiest way to do this would be using the HTTP POST method, but I'm having some issues with the syntax. After connecting to the network, successfully, I send the following AT commands (I've changed the AIO Key, but everything else is as it runs on my end):
AT+HTTPINIT //Initialize HTTP
AT+HTTPPARA="URL", "https://io.adafruit.com/api/v2/hurwitz_ ... test1/data" //Define URL
AT+HTTPPARA="USERDATA","X-AIO-Key: aio_ABCEDFGHIJKLMNOPQRSTUVWXYZ" //Define AIO key in Header
AT+HTTPPARA="CONTENT","application/x-www-form-urlencoded" //Define formatting as "form" for value=42
AT+HTTPDATA=12,2000 //Prepare to receive 12 bytes of data to send
"value=12.3"
AT+HTTPACTION=1 //Perform PUSH
AT+HTTPREAD=200 //Read Reply
AT+HTTPTERM //Terminate HTTP
I get an "OK" reply from the SIM7600 after each command (except the "HTTPDATA" command which replies with "DOWNLOAD" which tells me to input the text), but the reply I get from the server is:
HTTP Status 406: Invalid HTTP_ACCEPT Header:
And noting updates on my Adafruit IO Feed.
I'm clearly doing something wrong with the X_AIO_Key, but I've tried a bunch of different syntax tweaks and I can't seem to get to any success.
Has anyone successfully implemented this with SIM7600?
Thanks in advance!!
SIM7600 AT Commands for HTTP POST
