Lost connection to Adafruit.io server
Eduardo_Roots
Post by Eduardo_Roots »
[EN]
Hello, I would like to know how to handle the following event:
I use a NodeMCU ESP8266 board to access the Adafruit dashboard. It's working fine.
  • 1. I've already prepared in case you can't find the router's wifi;
  • 2. If connected and the router turns off, redo the connection;
  • 3. The problem is when the internet drops, and the router continues with the wifi on. I tried to use:
    • io.mqttStatus();
      io.networkStatus();
      io.status();
But none of the methods change the connection status if connected and only the internet stops working.
Does anyone know how should I proceed?
[PT-BR]
Olá, gostaria de saber como tratar o seguinte evento:
Uso uma placa NodeMCU ESP8266 para acessar o painel da Adafruit. Está funcionando bem.
  • 1. Já preparei para o caso de não conseguir encontrar o wifi do roteador;
  • 2. Se conectado e o roteador desligar, refaz a conexão;
  • 3. O problema é quando a internet cai, e o roteador continua com o wifi ligado. Tentei usar:
    • io.mqttStatus();
      io.networkStatus();
      io.status();
Mas nenhum dos métodos mudam o status de conexão se conectado e, apenas, a internet parar de funcionar.
Alguém sabe como devo proceder?
mikeysklar
Re: Lost connection to Adafruit.io server
Post by mikeysklar »
You can check to see if AIO is accessible from the ESP8266.
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.println(io.statusText());
delay(500);
Not Adafruit code, but an ESP8266 example of doing a http request to verify the internet is accessible.
https://gist.github.com/abachman/4cf133 ... db03b48948
Return to “Internet of Things: Adafruit IO and Wippersnapper”
