I have a data stream, for whatever reason is best sent as two values, separated by a comma.
Is there any way to separate them into two feeds?
Roger
Can data sent to AIO be parsed?
- mikeysklar
Re: Can data sent to AIO be parsed?
Roger,
There is a temperature humidity example here you can customize to your needs.
https://github.com/adafruit/Adafruit_IO ... umidity.py
while True:
humidity, temperature = Adafruit_DHT.read_retry(dht22_sensor, DHT_DATA_PIN)
if humidity is not None and temperature is not None:
print('Temp={0:0.1f}*C Humidity={1:0.1f}%'.format(temperature, humidity))
# Send humidity and temperature feeds to Adafruit IO
temperature = '%.2f'%(temperature)
humidity = '%.2f'%(humidity)
aio.send(temperature_feed.key, str(temperature))
aio.send(humidity_feed.key, str(humidity))
