Is there a fix for the above issue between Adafruit Airlift Breakout and the board 'adafruit metro grand central m4' ? I am trying to update the FIRMWARE VERSION on the two Adafruit Airlift Breakout. Is there a new Arduino compatible Adafruit WIFININA lib. ?
Thank you.
error: 'class WiFiClass' has no member named 'setPins'
- Giv
- dastels
Re: error: 'class WiFiClass' has no member named 'setPins'
You're using the Adafruit version of WifiNINA? As per https://learn.adafruit.com/adafruit-air ... ut/arduino.
You can check in Arduino's library manager for any updates to the library.
- Giv
Hi Dave,
No, It seems there are multiple WiFi.h and had to pick the correct one. I know I have the latest Arduino WiFiNINA "1`.8.13". But I found two other helpful posts on this issue:
and
Thank you.
viewtopic.php?f=53&t=158596&p=782046&hi ... M4#p782046
and
viewtopic.php?f=56&t=164725#p811069. You can close this issue.
Thank you.
- brubell
- Learn User Page
The Adafruit "fork"/version of WIFININA includes the setPins() function. The Arduino version does not.
Here's how to fix it,
1) Please uninstall the version of the WiFiNINA library you have installed in Arduino.
2) Then, follow the steps on this page to install the Adafruit version of WiFiNINA: https://learn.adafruit.com/adafruit-air ... -3024912-5
