Hi All,
I am trying to alert via SMS with an Action. I am trying to set up a webhook to send a message via Twilio. When sending the webhook I get a message returned saying
code": 20003, "detail": "Your AccountSid or AuthToken was incorrect.", "message": "Authentication Error - No credentials provided", "more_info": "https://www.twilio.com/docs/errors/20003", "status": 401
I am following the example from datadog site as it seems similar to IO. https://www.datadoghq.com/blog/send-ale ... ks-twilio/
I have confirmed that my Creds are good. However, the endpoint doesn't even seem to think I am sending any.
Anyone got any ideas?
Twilio Anyone got it to work?
- chrisrwebb
Re: Twilio Anyone got it to work?
Just an update on this I tried the datadog example on postman and it worked. Anyone know how IO is posting the data I think it needs to be as form-data.
- jwcooper
Thanks for the follow-up. We may need to add the option to post as form-data. That does look like the difference between IO and DataDog.
- chrisrwebb
I think what might be a good idea is to support basic auth in the requests. Allow for the ability to enter credentials to call the webhooks. That would likely allow you to support more services.jwcooper wrote:Thanks for the follow-up. We may need to add the option to post as form-data. That does look like the difference between IO and DataDog.
- jwcooper
We now have the option to encode the POST as form data when creating a webhook in an action. This may help this specific use case.
