lost connection recovery
Rcayot
Post by Rcayot »
I have a weather station that I have feeding AIO. The issue is that I have a poor internet connection by satellite. Every once in a while, depending on weather conditions etc., I temporarily lose my internet connection and the program feeding AIO crashes.
I have placed several tests for connection in the program and do not understand why they are not working. Here is partial code that first uses an 'if adafruit.is_active:' test, where "adafruit=PingServer('adafruit.com', event_delay=20.0)" is set in the early portion of the code.
while True:
    # Look for a new packet: only accept if addresses to my_node
    packet = rfm9x.receive(with_ack=True, with_header=True)
    # If no packet was received during the timeout then None is returned.
    if packet is not None:
        #print("Received raw packet:", [hex(x) for x in packet])
        payload = str(packet[4:], "utf-8")
        tag = int(payload[0])
        #print(tag)
        if tag == 1:
            temperature = payload[1:]
            temperature = (float(temperature)*1.8 + 32)
            temperature=round(temperature, 2)
            print("temperature = ", temperature, "F")
                aio.send(temperature_feed.key, str(temperature))
            else:
                print("wifi not ready")
        elif tag == 3:
            pressure = payload[1:]
            print("pressure = ", pressure, "mB")
                aio.send(pressure_feed.key, str(pressure))
            else:
        elif tag == 2:
            humidity = payload[1:]
            print("humidity = ", humidity, "%")
                aio.send(humidity_feed.key, str(humidity))
            else:
Occasionally I get an error message, quite lengthy, but the last portion is the following:
File "/home/pi/backup/Downloads/Adafruit_CircuitPython_RFM9x-main/rfm9x_flag_ack_aio_wind3.py", line 99, in <module>
File "/home/pi/backup/Downloads/Adafruit_CircuitPython_RFM9x-main/Adafruit_IO/client.py", line 154, in send_data
return self.create_data(feed, payload)
File "/home/pi/backup/Downloads/Adafruit_CircuitPython_RFM9x-main/Adafruit_IO/client.py", line 254, in create_data
return Data.from_dict(self._post(path, data._asdict()))
File "/home/pi/backup/Downloads/Adafruit_CircuitPython_RFM9x-main/Adafruit_IO/client.py", line 122, in _post
response = requests.post(self._compose_url(path),
File "/usr/lib/python3/dist-packages/requests/api.py", line 119, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python3/dist-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/Rcayot/feeds/humidity/data (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb4fcc3a0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
What I would like to know is why if adafruit.is_active: is true why does the code fail when the next line is executed:
            else:
Anyway, Is it the delay of 20s that is too slow? Is there another way in which I could error trap this problem such that the program just skips over that portion and prints "wifi not ready"?
Any help would be welcome.
Roger
eherrada
Re: lost connection recovery
Post by eherrada »
I think the best way to go about this would be to put the code in a try/except loop and then use watchdog timer (https://docs.circuitpython.org/en/lates ... index.html) to reset the device after waiting a bit if it gets disconnected
Rcayot
Post by Rcayot »
Eheradda,
Thank you, I will persue this.
Roger
DJDevon3
Post by DJDevon3 »
Your delay isn't the problem. In my production code I'm posting and getting every 1800 seconds (30 minutes). So, obviously 20 seconds is nothing. Actually, I consider 20 seconds extremely fast and aggressive as a frequency but it depends on your needs.
Rcayot
Post by Rcayot »
DJ,
The 20s delay is related to the implementation of 'PingServer':
The issue is that when I use PingServer to see if Adafruit.com is available such as:
There seems to be an issue with the connection, and the program crashes. I was trying to keep the program running instead of crashing, I do not care if a couple of data points go missing, I just want the program to recover.
The API for PingServer does not go into detail about the function of 'event_delay'
I did not post the entire code as it is somewhat lengthy. I am using adafruits async_io to manage 'cooperative multitasking' instead of the usual time.sleep, or checking for elapsed time using time.monotonic.
Roger
Rcayot
Post by Rcayot »
eherratta,
I have implemented a try/except in my code, the watchdog time will not work because I am running this code on a Raspberry Pi 4.
What I am having trouble with is how to implement the except portion of the function.
The end of the verbose errors log output is like such:
I have inserted this at the end of my program lop:
except (UnicodeDecodeError, RequestError) as exception:
        print("error detected")
    finally:
        continue
The concern I have is that I think 'RequestError' is a failure of the adafruit_io function, and the actual failure is in teh python3 libraries on my Pi-4.
I have yet to experience an error of this type, so, I do not know yet if it will work.
Roger
