According to the docs https://io.adafruit.com/api/docs/mqtt.h ... -get-topic one should send a message to ".../feed_name/get" to obtain the last published value on this topic.
This works fine when the client is connected with the clean_session flag set to true. However, I have been unable to make it work when the client does not have that flag set. Each time I send a message to the 'get' topic, the broker immediately disconnects.
I have been able to reproduce this on my desktop computer in two different languages (Dart and Toit), and have a wireshark trace that shows that the broker disconnects.
Is there anything I can do to avoid the disconnect? Is this a known limitation?
'get' on a feed disconnects when "clean session" is off
- floitsch_toit
- jwcooper
Re: 'get' on a feed disconnects when "clean session" is off
I don't believe this is a known issue. I'll file a bug report internally to take a look and see if something is triggering the disconnect.
