import time
import board
import busio
import displayio
from digitalio import DigitalInOut
import adafruit_bmp280
import adafruit_sht31d
import neopixel
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
from adafruit_hx8357 import HX8357
displayio.release_displays()
# This sketch should also work for the 2.5" TFT, just change the size.
DISPLAY_WIDTH = 480
DISPLAY_HEIGHT = 320
i2c = board.I2C()
bmp280 = adafruit_bmp280.Adafruit_BMP280_I2C(i2c)
sht31d = adafruit_sht31d.SHT31D(i2c)
bmp280.sea_level_pressure = bmp280.pressure
# Get wifi details and more from a secrets.py file
try:
from secrets import secrets
except ImportError:
print("Secrets File Import Error")
raise
# Initialize SPI bus
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
# Initilize ESP32 Airlift on SPI bus
esp32_cs = DigitalInOut(board.D13)
esp32_ready = DigitalInOut(board.D11)
esp32_reset = DigitalInOut(board.D12)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
status_light = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.2)
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets, status_light)
# Initialize TFT Display on SPI bus
tft_cs = board.D9
tft_dc = board.D10
display_bus = displayio.FourWire(spi, command=tft_dc, chip_select=tft_cs)
display = HX8357(display_bus, width=DISPLAY_WIDTH, height=DISPLAY_HEIGHT)
# Connect to WiFi
print("\n===============================")
print("Connecting to WiFi...")
wifi.connect()
print("Connected!\n")
# Your feed key might be different from the feed name (no underscore allowed).
# It's not your IO account key or feed name. It's the individual key for each feed.
# For example, create a feed "temp_test" at AdafruitIO it sets the key "temp-test".
feed_key = "sense-temp"
print("Connecting to AdafruitIO...")
while True:
try:
print("Connected!")
print("===============================\n")
print("Posting Value...")
publish = {"value": "{:.1f}".format(bmp280.temperature*1.8+32)}
post = wifi.post(
"https://io.adafruit.com/api/v2/"
+ secrets["aio_username"]
+ "/feeds/"
+ feed_key
+ "/data",
json=publish,
headers={"X-AIO-KEY": secrets["aio_key"]},
print(post.json())
post.close()
print("\nConfirmation Response...")
time.sleep(10)
get = wifi.get(
+ "/feeds/"
+ feed_key
+ "/data?limit=1",
json=None,
print(get.json())
get.close()
except (ValueError, RuntimeError) as e:
print("Failed to get data, retrying\n", e)
wifi.reset()
time.sleep(60)
continue
response = None
time.sleep(600)
Connected!
Connected!
Value: 89.0
Posting Value...
{'created_at': '2022-06-22T08:01:37Z', 'id': 'obfuscated', 'expiration': '2022-07-22T08:01:37Z', 'created_epoch': 1655884897, 'feed_id': obfuscated, 'value': '89.0', 'feed_key': 'sense-temp'}
[{'created_at': '2022-06-22T08:01:37Z', 'id': 'obfuscated', 'expiration': '2022-07-22T08:01:37Z', 'created_epoch': 1655884897, 'feed_id': obfuscated, 'value': '89.0', 'feed_key': 'sense-temp'}]
