MMQTTException: PINGRESP not returned
michaelmcs
Post by michaelmcs »
I am trying to 'publish' data to Adafruit.io and occasionally I get
after a call to mqtt_client.loop(), which halts the program.
I haven't been able to find the documentation that describes what that loop() call actually does.
I'm assuming that the
just means that Adafruit.io was temporarily unavailable. I could probably put the loop() call within a try/except/else block as it isn't critical that every datapoint is logged, but I sure would like to know what is happening.
mikeysklar
Re: MMQTTException: PINGRESP not returned
Post by mikeysklar »
Without knowing your hardware setup I’m just guessing that this might be the issue:
https://github.com/adafruit/Adafruit_Ci ... /issues/66
Which appears to be resolved in a recent commit here:
https://github.com/adafruit/Adafruit_Ci ... TT/pull/69
