To get the above project started I went over the schematics of the Metro M4 Express AirLift and its pin out to match it for my project, But it seems there are discrepancies. In the schematic the ESP_CS pin of the ESP32 module is connected to 3.3V through a 10Kohm resistor and also the ESP_RESET is connected to the ground through a 10Kohm resistor. In the Adafruit Metro M4 Express AirLift (WiFi) document, on page eleven these and other pins are not matching with the schematic 100%, I might be mistaking.
I would like to know the correct pin connections between the Airlift Breakout WiFi and the Metro M4 Express as it is on the Metro M4 Express AirLift.
Thank you so much.
Adding Airlift to Metro M4 Express
- Giv
Reason: Removed he large text
- dastels
Re: Adding Airlift to Metro M4 Express
Have a look at https://learn.adafruit.com/adafruit-airlift-breakout and https://learn.adafruit.com/adafruit-air ... -processor which should give you the required information.
- Giv
Hi Dave,
Thank you for the information you sent, it does help with the definition of the pins connected. However, I am still looking for a documentation/Pinout/schematic that shows how an Airlift Breakout module is connected\Added to a Metro M4 Express to change it into a Adafruit Metro M4 Express AirLift (WiFi). The SPI connections are staright forward and on the ICSP. Its only these pins on the Airlift Breakout module CS, GPIO0 RST and BUSY, that need to be connected to the correct pins on the SAMD51 to initialize the Airlift correctly. So, I like to know how it is done on the Adafruit Metro M4 Express AirLift (WiFi), which helps me with all the SAMD51 boards that I have.
Thank you again.
Thank you again.
- dastels
There's no set of correct pins; those can be connected to any digital io pins and initialized in the code. The MetroM4 Airlift uses pns internal to the board that aren't brought out to the headers so you will be unlikely to replicate the connections at an MCU pin level. So you can't change a MetroM4 + Airlift breakout into an exact replica of am MetroM4 Airlift.
- Giv
Thanks Dave for getting back to me quick.
Regards.
Regards.
- Giv
Dave,
By the way, is that a proprietary information or Open Source and can you share it with me please.
Thanks a bunch.
Thanks a bunch.
- dastels
It's all available. Check the Airlift related product tutorials https://learn.adafruit.com/search?q=airlift. All the infor is there, including schematics.
- Giv
Dave, no sorry the information I am asking for is not there. Thank you for your help.
- DJDevon3
https://learn.adafruit.com/adafruit-met ... /downloads
All the schematics for a board can be found within it's learn guide on the downloads page for that board. I've checked and the schematics are in the right places on the correct pages.
If you're asking someone to show you a diagram for connecting the Metro M4 express to the airlift breakout module that also exists in the learn guide that Dave correctly showed you here: https://learn.adafruit.com/adafruit-air ... ut/arduino
Nothing in the Adafruit ecosystem is proprietary. You can find source code and schematics for any Adafruit product which sometimes involves searching on github.
- Giv
DJDevon3 ,
Thanks for your reply, but I have already looked around. I may have to buy one of these Adafruit Metro M4 Express AirLift (WiFi), and hack it to get my answer.
