Get Data for Multiple Feeds
- mdavey66
My cursory searching didn't find an answer. But is it possible to get feed data from multiple feeds with one call? Ideally, also using a time range? Or for a time range is it possible to get data from a group of feeds?
- Franklin97355
Re: Get Data for Multiple Feeds
What type of data are you trying to collect and how do you want to get it?
- mdavey66
I have time series environmental data and am using the API to download the data for post processing. Was wondering if there was a way to download multiple feeds with one call or would need to make one call per feed.
Basing everything off the API documentation example and parsing the JSON response:
"https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data?start_time=2019-05-04T00:00Z&end_time=2019-05-05T00:00Z"
- jwcooper
You can get the data for all the feeds in a group by using the following call:
https://io.adafruit.com/api/docs/#get-d ... -39-s-feed
So you'd create a group, and add feeds to it, that way you can have it all contained and utilize the group functionality in the API.
