Greetings
I presently have three feeds temp,pressure,humidity.
Can I show all three feeds by creating one block?
I noticed the temp reading is 32,the humidity is 35 but pressure is 970.
Or do Ineed a block for each reading?
Tom
Dashboard Question
- jwcooper
Re: Dashboard Question
Some blocks can have multiple feeds attached, and some only allow a single feed.
You could use a "Stream" block and just see the data stream in like from a log file, multiple feeds works fine with that.
Chart block allows up to 5 feeds, but you may want pressure on it's own chart as it will distort the temp/humidity a bit.
Could use a text block to just show the value of each feed individually (one block per feed) in big numbers.
Lots of options to try to see what looks best.
