Saving data to feed causes ESP32 to reset
AaronHe
Post by AaronHe »
Hi all! I'm new to Adafruit IO and have been test driving numerous example sketches on my ESP32 boards and for the most part I have been having great success however I am stuck with one issue in uploading an image from my WROVER board that uses an OV2640 camera that I was hoping someone might be able to help me with.
The board resets with the following when the line "cameraFeed->save(encrypt)" is executed:
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13516
load:0x40080400,len:3604
entry 0x400805f0
If I grab the value of "encrypt" and upload it to the feed data via the API (https://io.adafruit.com/api/v2/<myUsern ... key=<myKey>) the image saves and displays fine so I am certain the base64 value is ok.
Hopefully I have just done something stupid in my code and one of you awesome gurus out there can steer me right.
Here's my code:
#include "config.h"
#include "esp_camera.h"
#include "base64.h"
#define PWDN_GPIO_NUM    -1
#define RESET_GPIO_NUM   -1
#define XCLK_GPIO_NUM    21
#define SIOD_GPIO_NUM    26
#define SIOC_GPIO_NUM    27
#define Y9_GPIO_NUM      35
#define Y8_GPIO_NUM      34
#define Y7_GPIO_NUM      39
#define Y6_GPIO_NUM      36
#define Y5_GPIO_NUM      19
#define Y4_GPIO_NUM      18
#define Y3_GPIO_NUM       5
#define Y2_GPIO_NUM       4
#define VSYNC_GPIO_NUM   25
#define HREF_GPIO_NUM    23
#define PCLK_GPIO_NUM    22
unsigned long lastUpdate;
camera_config_t config;
AdafruitIO_Feed *cameraFeed = io.feed("camera");
  Serial.begin(115200);
  Serial.setDebugOutput(true);
  Serial.println();
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  config.frame_size = FRAMESIZE_SVGA;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    delay(1000);
    ESP.restart();
  } else {
    Serial.println("Camera configuration complete!");
  sensor_t * s = esp_camera_sensor_get();
  s->set_framesize(s, FRAMESIZE_CIF);  // UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  Serial.println();
  Serial.println(io.statusText());
  log_d("Total heap: %d", ESP.getHeapSize());
  log_d("Free heap: %d", ESP.getFreeHeap());
  log_d("Total PSRAM: %d", ESP.getPsramSize());
  log_d("Free PSRAM: %d", ESP.getFreePsram());
  io.run();
  if (millis() > (lastUpdate + 5000)) {
    camera_fb_t *fb = NULL;
    fb = esp_camera_fb_get();
    if (fb != NULL) {
      String encrypt = base64::encode(fb->buf, fb->len);
      esp_camera_fb_return(fb);
      Serial.println(encrypt);
      cameraFeed->save(encrypt);
    } else {
      Serial.println("Camera Error");
    lastUpdate = millis();
brubell
Learn User Page
Re: Saving data to feed causes ESP32 to reset
Post by brubell »
Hi, the stack trace from the ESP32 is unfortunately not helpful without the decoded output.
Install https://github.com/me-no-dev/EspExceptionDecoder and follow the usage steps (https://github.com/me-no-dev/EspExceptionDecoder#usage). You should end up with a human-readable error output. Please copy and paste that here so someone can assist you.
AaronHe
Post by AaronHe »
Thanks brubell. Here's the decoded output of the backtrace:
0x40083901: panic_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/panic.c line 402
0x4008d379: esp_system_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/esp_system.c line 128
0x400928fd: __assert_func at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib/assert.c line 85
0x40083d5e: heap_caps_free at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap/heap_caps.c line 324
0x4009292d: free at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib/heap.c line 39
0x400dbc16: String::invalidate() at C:\Users\aaron\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32/WString.h line 343
0x400dbc25: String::~String() at C:\Users\aaron\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32\WString.cpp line 159
0x400d3f9b: AdafruitIO_Feed::save(String, double, double, double) at C:\Users\aaron\Documents\Arduino\libraries\Adafruit_IO_Arduino\src\AdafruitIO_Feed.cpp line 152
0x400d37ba: loop() at C:\Users\aaron\Desktop\adadfruit_io_camera_test/adadfruit_io_camera_test.ino line 93
0x400dc0fd: loopTask(void*) at C:\Users\aaron\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32\main.cpp line 50
brubell
Learn User Page
Post by brubell »
Could you isolate part of the code which sends the camera feed's string out of the code (make a new sketch and try sending the b64 string to IO)?
AaronHe
Post by AaronHe »
Thanks for the advice brubell. I stripped the code back however it still crashed. Here's my code, however I had to remove the value of "encrpyt" as the forum rules would not let me post it (it violated the banned spam rules):
#include "config.h"
  Serial.println();
  io.connect();
    Serial.print(".");
    delay(500);
  String encrypt = "<base64 encoded string>";
Decoding stack results:
0x40083a5b: find_containing_heap at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap/heap_caps.c line 316
0x40083bf9: heap_caps_free at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap/heap_caps.c line 338
0x40091c95: free at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib/heap.c line 39
0x400d6b96: String::invalidate() at C:\Users\aaron\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32/WString.h line 343
0x400d6ba5: String::~String() at C:\Users\aaron\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32\WString.cpp line 159
0x400d2df3: AdafruitIO_Feed::save(String, double, double, double) at C:\Users\aaron\Documents\Arduino\libraries\Adafruit_IO_Arduino\src\AdafruitIO_Feed.cpp line 152
0x400d274e: setup() at C:\Users\aaron\Desktop\adadfruit_io_camera_test_basic/adadfruit_io_camera_test_basic.ino line 15
0x400d6eaa: loopTask(void*) at C:\Users\aaron\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32\main.cpp line 42
brubell
Learn User Page
Post by brubell »
You could try increasing the MQTT library's max buffer size, https://github.com/adafruit/Adafruit_MQ ... QTT.h#L110
AaronHe
Post by AaronHe »
Thanks again brubell. I tried increasing the value of MAXBUFFERSIZE from the default 150 in small increments up to 300 and I also tried much larger values up to 4096 and unfortunately it still isn't working.
brubell
Learn User Page
Post by brubell »
AaronHe wrote:Thanks again brubell. I tried increasing the value of MAXBUFFERSIZE from the default 150 in small increments up to 300 and I also tried much larger values up to 4096 and unfortunately it still isn't working.
Could you try sending the data using the Adafruit MQTT library only, to isolate the issue, https://github.com/adafruit/Adafruit_MQTT_Library
AaronHe
Post by AaronHe »
Hi again brudbell, I can confirm that using the Adafruit MQTT library works fine.
In my test, the MAXBUFFERSIZE had to be increased to 12500 otherwise the value was truncated to 125 chars.
