Has anyone gotten Adafruit IO IOT system to work with Heltec Wifi Kit 32 boards? Any pointers would be welcome. I am using platformio/Visual Code Studio as my development system and get tons of conflicts when I try to use the Adafruit IO library with the Heltec Wifi Kit 32.
Heltec WIFI Kit 32 with Adafruit IO IOT
- brubell
- Learn User Page
Re: Heltec WIFI Kit 32 with Adafruit IO IOT
Which library are you using? Could you provide a URL?
- peteDD
The "Adafruit IO Arduino" library loads via Platform IO and is version 4.2.0 and shows Adafruit as the Author/maintainer.
The intro statement for the library is "Arduino library to access Adafruit IO. Arduino library to access Adafruit IO using the Adafruit AirLift, ESP8266, ESP32, ESP32-S2, M0 WINC1500, WICED, MKR1000, Ethernet, or FONA hardware."
Does that help any?
Does that help any?
- brubell
- Learn User Page
Could you copy the errors from your compiler and paste them here?get tons of conflicts when I try to use the Adafruit IO library with the Heltec Wifi Kit 32.
- peteDD
I've since moved on to another IOT platform.
