Hi Gang
I've two weather stations. They are identical in both hardware and software. They publish humidity, temperature, wind direction and wind speed every fifteen minutes. The second weather station however stops publishing wind direction outside the hours of approximately 9AM to 4PM (AEST). I've tried replacing the PCB, microcontroller (Arduino Nano 33 IoT) and wind direction sensor with no change. I'm beginning to wonder whether there may be a problem the other end? Is there a data limit with adafruit IO? Is there an issue with that specific feed? Any help would be really appreciated.
https://io.adafruit.com/jwtfpv/dashboar ... beechworth
https://io.adafruit.com/jwtfpv/dashboar ... n-chiltern
Cheers
Jase :)
RE: Weather Stations
- dastels
Re: RE: Weather Stations
An Adafruit IO+ account gives you 60 data points per minute. The free account gives you 30. If you exceed that you get throttled. How often are your systems posting data?
- jwtfpv
Hi dastels
Thanks for getting back to me. Each weather station is publishing humidity, temperature, wind direction and wind speed every fifteen minutes.
Cheers
Jase :)
Cheers
Jase :)
- dastels
The average rate isn't a problem. I wonder if there's a finer granularity limit. What happens if you put some time between posts spacing them out a bit?
- jwtfpv
Hi dastels
I've changed both units to publish every thirty minutes. Let's see what happens.
Cheers
Jase :)
Cheers
Jase :)
- jwtfpv
Hi dastels
I know it's only been a couple of hours but it's not looking promising. I'll let it run twenty four hours and see what happens. Any other thoughts?
Cheers
Jase :)
Cheers
Jase :)
- dastels
How many posts happen each time?
- jwtfpv
Hi dastels
Currently each weather station publishes four to six bytes every thirty minutes.
Cheers
Jase :)
Cheers
Jase :)
- dastels
Is that 4-6 individual posts.. or all in one post?
- jwtfpv
Hi dastels
As usual the weather station had started publishing wind direction at 9AM.
Cheers
Jase :)
Cheers
Jase :)
- jwtfpv
Hi dastels
Information as requested.
1. Connect to server.
2. Connect to broker.
3. Begin message (topic0), publish humidity (byte) then end message.
4. Begin message (topic1), publish temperature (byte) then end message.
5. Begin message (topic2), publish wind direction (1 - 3 bytes) then end message.
6 Begin message (topic3), publish wind speed (byte) then end message.
7. Disconnect broker.
8. Disconnect server.
Cheers
Jase :)
Cheers
Jase :)
- dastels
So 4 posts in a row. You could try spacing out those 4 posts.
- jwtfpv
Hi dastels
I tried placing a delay between publishing each feed but still no joy. I ended up opening the wind direction sensor yesterday afternoon in desperation. There was an IC had not been soldered and was literally sitting on the PCB. Since addressing this issue it appears to works. No wonder I'm getting more and more grey hair!
Thanks for all your help.
Cheers
Jase :)
Cheers
Jase :)
- dastels
Bad connections will get you every time.
- jwtfpv
I spoke too soon. :(
